Roof drains
. Has anyone else come across this same issue? If so, what did you do to resolve it? I’m thinking I can sleeve the two ends with a slightly larger diameter pipe as a last resort but just wanted to hear your thoughts based on experience.
TIA Alan.
I’ve just found my passenger mats wet and found this thread.
same issue with the pipe being disconnected & too short to reach the rubber elbow.
turns out that the drain pipe had been clipped up with the electrical wires in the A pillar and so ran a longer route.
unclipped and shifted it to what appear to be the correct metal clips. Freed up the pipe, all connected properly again & fingers crossed problem solved. HTH.
wrong!
right!
An old thread I know but it’s topical at this time of year. I had a look at mine and both the front drains were blocked. I used my portable garden sprayer and squirted some water into the top drain points……. Worked like a dream :thumb There is a strange satisfaction hearing the gurgling sound than others have mentioned elsewhere when testing them:)
JohnCalifornia
Taff Tenor
Taff Tenor
mrcheesbrough
mrcheesbrough
jonddd
Steeble
jepotherepo
jepotherepo
