westfalia
My roof hydraulics are bolloxed.
Put the roof up today and it wouldn´t come down on one side, proper fixed, wouldn´t budge
even trying to pull it down with the button pressed at the same time.
So i removed the control panel and in doing so i managed to pull the display away from the circuit board
and pull off a ribbon wire thing so thats bolloxed too.
Anyway the control panel is now on it´s way to holland for a repair.
I got the roof lowered by undoing the screw.
There doesn´t appear to be any oil leaks anywhere.
The question is.
Can i replace one of the hydraulic rams without having to pressure the system up again ?
Or will the ram be full of oil therefore the system will need more oil ?
On the bright side- at least it happened at home.
The question is.
