GrumpyGranddad
Probably something worth doing periodically.Followed the advice on forum. Raised and lowered 5 times and it seems to have worked. Roof been up for almost 3 days with no sag.
This could be down to the outside temperature now it’s colder the oil is thicker which means it can’t pass over the pump non return,but fingers crossed it’s sortedFollowed the advice on forum. Raised and lowered 5 times and it seems to have worked. Roof been up for almost 3 days with no sag.
That worked once for me, problem re-occured the next time I had the roof up. I tried the 5 times trick again and it didn't work.Followed the advice on forum. Raised and lowered 5 times and it seems to have worked. Roof been up for almost 3 days with no sag.
I will monitor and update forum if necessary. Northern Spain certainly wasn’t too hot when it happened but we’ll seeThis could be down to the outside temperature now it’s colder the oil is thicker which means it can’t pass over the pump non return,but fingers crossed it’s sorted
ThanksThe VW procedure is similar to 5x up and down but not exactly the same (requires modulation of the bypass valve).
VW says to repeat the whole procedure up to 3 times.
OMG. I’ll monitor and will put roof out again once this downpour stops. Thanks for infoThat worked once for me, problem re-occured the next time I had the roof up. I tried the 5 times trick again and it didn't work.
Mine happened within minutes of putting the roof up and meant the lights didn't work in the pop top when it sagged. The camper display showed the roof was in "intermediate position" - put the roof up and they worked again. Ten minutes later intermediate position again and no lights. I'd say that's not within acceptable limits if that's what you are seeing, it's hardly practical to keep putting the roof up every ten minutes so you can have the lights on.
Now the rain has stopped (2 weeks later) I’ve had the roof up again for 36 hours and pleased to say it hasn’t sagged again. Fingers crossed the forum advice (raise and lower 5 times) has done the trick.Followed the advice on forum. Raised and lowered 5 times and it seems to have worked. Roof been up for almost 3 days with no sag.
I have just experienced the exact same problem on my 22 T6.1 for the first time this year, having only had roof up twice this year.After 2 nights the drivers side roof on our t6.1 brand new in May this year had sagged enough to stop roof lights from working the ram had moved about 2 inches I booked it In at our local VW dealership where it was purchased from they have had it for 3 days but claim the roof hasn’t sagged this is the second time it has been in for the same problem though last time they only had it over night I showed video and photo evidence of the sagging when I took the van in. I have now left it with them for a further 2 nights so see if they can see any sagging not sureView attachment 113673 where to go from here if they say there is no View attachment 113674problem with it as it’s my word against theirs. Anyone had similar issues ?
