sidepod
- Messages
- 6,043
- Vehicle
- T4 PopTop
So truly terrifying then!. Seems to float at higher motorway speeds.
I’ll measure mine tomorrow, maybe Wednesday when I’m home and used half a tank of Diesel.Interesting that you say that, we were discussing at home yesterday how much better our 23MY 4 motion seems to ride than our previous 20MY 199 FWD
I measured the hight from the ground to the top of the wheel arch & its sitting almost 40mm lower than our previous van!
What???Regardless of what many will claim its simple physics that any lowering of suspension has to be achieved with accompanied increased spring rate (maybe achieved by increasing the rate of progression) otherwise you find the bumpstops. Lowered suspension will not soften the ride period.
That might even make the Sharavan a worthwhile purchase....... maybeWe had just had an unexpectedly enjoyable afternoon at the beach with sunshine and ice creams.
What model are the Koni‘s and are you set up on standard springs ?Having just returned from half term trip to Anglesey I noticed a slight change in my view of the suspension with Koni shocks. There were a couple of times at almost exactly 40mph down some country lanes that were wide enough to have a white line down the middle, where I actually would say I found it a teeny bit enjoyable to drive. Just a bit.
I have usually laughed at people who claim their van handles well. My view has always been its a top heavy van and is never ever going to be a Gti or even an X5.
Other things that might have contributed to this slight positive change ~
When I’m in Anglesey, I’m not camping so the van isn’t loaded up, in fact it only contained 2 adults, 2 kids, 4 pairs of wellies and a kite.
For a van that heavy, I really think it handles well. It's no comparison with my Golf 4 I had before, but even then, it sticks much much better to the road than the Golf with it's fixed rear axle.I have usually laughed at people who claim their van handles well. My view has always been its a top heavy van and is never ever going to be a Gti or even an X5.
CRS vanilla active Konis. No change to springs. He raised the back by 12mm or something. A quite old 2008 van on 16” wheels.What model are the Koni‘s and are you set up on standard springs ?
Diy or got it done somewhere?
Explain to me how the simple lower arm/strut achieves progression? There’s no additional linkage to alter the ratio. The wheel moves 50mm, the spring compresses 50mm.Regardless of what many will claim its simple physics that any lowering of suspension has to be achieved with accompanied increased spring rate (maybe achieved by increasing the rate of progression) otherwise you find the bumpstops. Lowered suspension will not soften the ride period.
Think youve missed the point that transporter suspension mods if the lowering isnt combined with either a higher spring rate than stock or a spring that is wound such that it has a higher rate of progression than stock. For the same pothole at same speed as stock you would use up your greatly reduced wheel travel and find the bump stops. Transporter does not have race car suspension where ride height can be adjusted independetly of spring length / rate. Thus lower = harsher or frequent bottoming out on the bump stops.Explain to me how the simple lower arm/strut achieves progression? There’s no additional linkage to alter the ratio. The wheel moves 50mm, the spring compresses 50mm.
You can alter ride height all day long without changing spring rate. Race cars do it all the time.
Waft is probably a better description then.So truly terrifying then!
Thing is , there is plenty of redundancy in the travel so it’s unlikely to hit the bumps stops more often. Even if it does, so what.Think youve missed the point that transporter suspension mods if the lowering isnt combined with either a higher spring rate than stock or a spring that is wound such that it has a higher rate of progression than stock. For the same pothole at same speed as stock you would use up your greatly reduced wheel travel and find the bump stops. Transporter does not have race car suspension where ride height can be adjusted independetly of spring length / rate. Thus lower = harsher or frequent bottoming out on the bump stops.
Hi David ,Hi All
My wife and I own a 61 plate California SE, 180 DSG which we have had for 6 months. While we are really impressed with nearly everything about the camper, the ride leaves a lot to be desired. At best I would say it's really crashy, you can feel every bump in the road, and when you hit a small hole it sounds like the van will fall apart.
I'm going up to VW on Tuesday to see what they say. I would like them to check out the suspension If there is nothing wrong I would like to know if there are any options to improve it. Maybe lowered springs or different tyres???
I would like to know other peoples thoughts on this. We can't be the only ones to think the ride is terrible. It is that bad that my wife is starting to refuse to go anywhere in it. Not enjoyable, rather tiring, even a small journey is unbearable.
I have checked tyre pressure, removed everything from the van but it's still the same. To me it sounds like the dampers just keep rebounding and aren't damping out the shock.
If I can't get anything sorted we are at the point where we will have to sell, it's that irritating...
Thoughts greatly appreciated.
David
