Water through outside table release handle in sliding door
Grigio Van Grigio
Grigio Van Grigio
High Peak
T6.1 Ocean 150
Hi,
Has anyone else had water coming through the table release handle in the sliding door after rain? Could this be a potential leaking window? Van is three weeks old so I wouldn’t have though there were any blocked drainage holes and they look ok.
My bet would be the leaking sliding window drains, which are prone to suffer from a design/production flaw, resulting in them draining into the van rather than out. Lots of posts if you search “window drains” also I’ve put some details in the Resources section.
Assuming it is the drains then the fix is to replace the whole window.
Awesome. Van now leaks in three places!
Thanks for you help.
Have you checked that the kitchen window isn’t leaking? Normally shows up as water on top of waste tank and in cupboard.
I need to check property. Looked ok earlier but haven’t had everything out. Thanks for the heads up.
