Which is the quickest and easiest awning to put up??
P
Polomint
West Sussex
Hi Everyone,
Already have an awning room, but am finding it difficult to put it up with out leaving gaps between the front and side panels.
We are considering a small awning that fits to a closed awning rail.
Which awnings do you have and how easy are they ro put up for short stays?
Thanks In anticipation
Hi.
Moderators I haven't seen this post come up on the forum,
Is there something not right??
Hi Everyone,
What awning room do you have? We have the comfortzleisure room and found that it isn’t what you would call a snug tight fit on the sides where it touches the van it certainly does the job. We have gone through some quite bad weather and it’s always stayed pretty dry providing you use the rafter pro and get the slope right so the rain doesn’t puddle and it can run off nicely.
We can get ours up fully in about 20 minutes ish depending on the condition of the ground knocking the pegs in.
We have the infill panels so the sides near the van are fine, its the other 2 corners with gaps.
Is there a certain angle you need the wind out awning at??
Has anyone got pictures of the awning up both inside and outside views would be useful.
