ABS / ESP warning lights
alistairjkerr
Aberdeen
T6 Ocean 204
Hi Folks, I have an ABS / Traction Control / Tyre pressure / stop start error on the dash.
I’m getting error code 04199, which will not reset. I believe it is ‘Telemetry control module, GPS module’ can anyone confirm the code and any ideas what it means?
I’m also getting other codes which reset and occasionally reappear.
00087 - Terminal 30 for Starting Relevant Consumers
00089 - Line monitoring for clamp 30 starting battery
00091 - Signal ignition key puts
00095 - Engine for central locking, door in the back right, LOCK (V215)
00298 - Rear Differential Lock Switch (E121)
Any suggestions for things I can check before it heads to the garage would be appreciated?
1. Check the engine battery charge status. Low battery often brings up some weird errors .
2. ABS, Traction Control etc is often related to a failed/failing ABS sensor.
You may get better info on the T6 forum. Some clever members their really into vehicle electrics/electronics .
