Martin
Administrator
Admin/Founder
This information has been kindly supplied by @Ewan from Wild About Scotland
Roof Corrosion Key Facts
Hi
My 2014 Beach has corrosion on the elevating roof sections n under the rubble seal. VW have authorised work under warranty .. 6 to 8 months lead time. Not acceptable. I discussed lower resale values but VW say it won't effect the resale value. They say it would have 6 years warranty so by the time the work is done be it will only have 2 years left. Anyone ne in the same position?
Hi,
Has anyone took legal advice about this?
Nice article, there is another point to add in your "what causes" section that relates to the rubber seal and its metal strip.That's my understanding too:
"It seems that VW changed the manufacturing process sometime in March 2013 to include an additional plastic strip fitted in the gutter between the elevating roof and the front panel, and also used front panels with a different aluminium alloy construction. This changes should now have fixed the problem affecting the front panel. However, many 2014 vans still seem to suffer from roof corrosion on the main elevating roof and a permanent fix for this hasn't yet been found".I've updated the article just now following feedback clarifying the causes of the problems (and will continue to provide updates as and when there are any new developments).
Thank you so much for this. Just noticed a second batch of corrosion on my 2008 Cali - the first time was before I was aware of the issue and paid for a bodywork repair myself. I feel pretty stuffed now.This information has been kindly supplied by @Ewan from Wild About Scotland
I have been persuing my roof repair since 2013. At last I have a date for the pick up for repair. My local dealer has done what he can to push this but my VW customer service person left without leaving any info for his replacement. Anyway after chasing the repair and getting a new set of photos its being repaired. I'll let you know how it looks.This information has been kindly supplied by @Ewan from Wild About Scotland
The link to this information seems to not work nowThis information has been kindly supplied by @Ewan from Wild About Scotland
Thank you so much for that
