Thank you. I did see some photos online which looked as though it was possible to make the connection but in many ways easier, just fill a bucket from the rear shower connector and go from there.I don't think you can connect it to the rear shower. You would need to connect the rear shower output valve to the kampa inlet and then connect the cali shower to the kampa output. Assuming the fittings are different. Also then you would have to run the cali water pump at the same time as the kampa geyser. The geyser is more of a stand alone unit with it's own shower head etc
You just need a waterproof sack, bucket or portable container filled with water, geyser will pump the water from this and heat it.
Drop the water pump shown in the photo into the water source.
Thanks, good to know. Lots of options there.Hi,
it is possible as the Geyser will take its input water from any source not nessessarilly from its own pump. The outlet from the van requires the van pump to be running so that is creating the pressure for the geyser. As the van QR connection is not standard it is simplest to use an original VW shower hose connected to the van. The shower head connection is standard so use that with a male/male connector which you can then connect to the geyser fitting.
overall the original problem remains I.e it is quicker to fill a bucket with water than it is to refill the vans tank with water so I see the geyser as a stand-alone item.
So, I have done exactly this, it gives us the ability to use the van tank if we have to, clearly it won't last very long.Thanks, good to know. Lots of options there.
Thanks, that looks like a good set up, I like to have options and the ability to hook up to the shower or just fill a bucket works for me. I will go and investigate hoses and connections!So, I have done exactly this, it gives us the ability to use the van tank if we have to, clearly it won't last very long.
I made a link pipe, which doesn't use the pump from the kit. I connect to the Geyser directly and switch on the pump from the van shower outlet. From what i can determine the pump used in the van can run continuously, even if water is not flowing, so you can still use the shower head switch on the Geyster to save water.
After lots of research, I determined the shower outlet is basically a modified gas quick release coupling, with an extra pin on the shower end and slot in the van connection, I assume to prevent the shower head being connected to a bbq point on a caravan. So i used a quick release gas connector end and the Geyser quick release on the other, lack of pin isn't a issue on the hose end.
The pipe I used is not ideal as it is rigid, but it was all i could get with shops shut last year.
Double up as a pillow!You might find that you use the van tank capacity quite quickly, so if you staying somewhere for a while something like the below might work (provided the pump will fit into the bag):
Plastimo Flexible Fresh Water Tank - 100LTR - Marine Scene
Plastimo water tanks consist of a welded non-porous tasteless PVC water chamber (inner bladder) inside a tough nylon envelope, for complete watertightness and rwww.marinescene.co.uk
