As you are probably fully aware in France if over 500kgs you will have a trailer with its own registration and insurance.Anyone with advice regarding travelling around Europe towing a small Trailer??
The only downside is speed limit normally 10 kph less and ferries and tolls are higher .
750kg Trailer licence, unless test passed pre 1997, isn't related to the towing vehicle just any trailer over that grosse weight. ie in UK you can tow a 750kg trailer on just a car level licence but a B+E needed for any trailer over that weight even if towing with a small car.Its normally a lot more than 10kph less on motorways:
eg france motorway - 90kmh v 130kmh
Spain motorway 90kmh v 120kmh
Norway if trailer is braked 80kmh v 110kmh
Norway if trailer is unbraked over 300kg max 60kmh
Also need to look at driving license carefully if you don't have B+E ie a towing license as you are limited to a max 750kg trailer behind a cali as you will be over the 3500kg threshold.
No that is not correct.750kg Trailer licence, unless test passed pre 1997, isn't related to the towing vehicle just any trailer over that grosse weight. ie in UK you can tow a 750kg trailer on just a car level licence but a B+E needed for any trailer over that weight even if towing with a small car.
Stand corrected in part.No that is not correct.
B licence lets you have train weight up to 3500kg, or a tow vehicle up to 3500kg + max 750kg trailer.
A 2000kg MAM car + 1500KG trailer is allowed.
A 3100kg cali + 750kg trailer is ok on a B licence
You quote a 3100kg Cali plus a 750kg being OK with a combined MAM of 3850kg
MAM of my Cali is 3080kg which would mean that not even a 500kg trailer could be towed without a B+E licence.
From GOV.uk
- tow a trailer over 750kg MAM as long as the combined MAM of the trailer and towing vehicle is no more than 3,500kg
Got it now as it was as first my rule of thumb in needing the B+E if over 750kg was when I checked a few years back.No you've miss read that - it says you can't tow a trailer OVER 750kg if the MAM is more than 3500KG.
ie you are limited to a 750kg max trailer if you are going over the 3500kg.
