Turn Signal Volume
G
GrumpyGranddad
Guest User
Does anybody know if it is possible to increase the volume of the turn signals on a T6.1?
I don't know - but I would also like to know.
Back in the good old days when I drove a '63 850 mini the trick was to mount the flasher unit onto a spray can top to amplify the sound. It worked well, but I can't bring myself to try it on my T5.1!
I had a look at the adaption maps and cannot see a setting for this.
What makes the indicator noise, a speaker controlled by the BCM or a relay?
Whichever it is i suppose you could use a relay, triggered by the “ noise maker” to power a small speaker/ electronic circuit + speaker, with a volume control.
Its a small speaker in the rear of the instrument cluster
