SamSara
Hi, i want a solar panel to extend or life for a few more days. So ,any to choose from i would appreciate guidance. I do not want one on the van and i would like ease of setting up.
thanks
thanks
www.jackery.com
I use to have 100w portable one I bought from go outdoors, suitcase type.Hi, i want a solar panel to extend or life for a few more days. So ,any to choose from i would appreciate guidance. I do not want one on the van and i would like ease of setting up.
thanks
It appears I must stand corrected!Don't believe it's as simple as just plugging a solar panel in, there's a whole load of other electronic trickery involved.
Crikey, that is a fair wedgeI use to have 100w portable one I bought from go outdoors, suitcase type.
Only needs live and neutral off battery as everything is built in on the back.
Sold it as was to big to store, and had to chain it to wheel (worried it would get pinched).
The flexi type are harder to secure but I may look at getting one as an extra.
There is a windscreen cover now you can buy with two panels built in, not cheap thoughView attachment 91266
I’m sure I’ve seen a cheaper version somewhere.Crikey, that is a fair wedge
We use an alternative approach we use a solar generator to charge all the phones and iPads etc then the leisure battery in the van only needs to cover the fridge which we found works ok if it’s down to temp on the journey then turned down to 3 on site, then evenings few bits of lights. The battery blasts about three days then, we have a solar panel that attaches to and charges the solar batteryHi, i want a solar panel to extend or life for a few more days. So ,any to choose from i would appreciate guidance. I do not want one on the van and i would like ease of setting up.
thanks
I couldn't find "Sunpower Gold" on Amazon UK. Do you have a link please?I use a sunpower gold from amazon, bargain at £129.00 when i bought it. Comes with solar controller( cheap one but works) and various connectors.. we do festivals and tops the battery up a treat. 130 watt and folds into a case that sits on the parcel shelf. On a good day i get approx 6 amps out of it. Just clips onto battery under passenger seat or rear cupboard.
Hi @SamSaraHi, i want a solar panel to extend or life for a few more days. So ,any to choose from i would appreciate guidance. I do not want one on the van and i would like ease of setting up.
thanks
It was a while back, i will ave a look at my historyI couldn't find "Sunpower Gold" on Amazon UK. Do you have a link please?
Ive had a look around and my purchase is no longer in my bought items box but has sungoldpower on the case. Only one i can find on amazon now similar is over 600 quid. SorryI couldn't find "Sunpower Gold" on Amazon UK. Do you have a link please?
https://www.amazon.co.uk/dp/B07SZFX59Z/?tag=unique09f-21Ive had a look around and my purchase is no longer in my bought items box but has sungoldpower on the case. Only one i can find on amazon now similar is over 600 quid. Sorry
Neat solution! Does this come with controller? Is the connection wire (the black one) not hampering your roof when driving, or do you disconnect it then (and leave it where?). I am very interested and interested in your reply? Thanks in advanceHave also just fitted a semi-permanent 100w panel (just bolts to roof rails). Easy installation and works brilliantly. View attachment 91624
Check out https://www.solarcampersolutions.co.uk/Neat solution! Does this come with controller? Is the connection wire (the black one) not hampering your roof when driving, or do you disconnect it then (and leave it where?). I am very interested and interested in your reply? Thanks in advance
krgds
There is a choice of controllers - I opted for one that has a Bluetooth connection so can be set and monitored via my phone. The curly cable stays permanently connected to make the most of every bit of sunlight. No issues at all when driving. You could disconnect and leave it in the rear cupboard if it bothered you but I can't see the point.Neat solution! Does this come with controller? Is the connection wire (the black one) not hampering your roof when driving, or do you disconnect it then (and leave it where?). I am very interested and interested in your reply? Thanks in advance
krgds
