GavinCapel
Looking at that Display, if you have the panel in full sunlight, with no shadows across it, then the likelihood is that the panel is failing and probably needs replacing.We have an issue with our Solar Panels that were fitted under previous ownership. Could anyone recommend a technician to diagnose the issue so we know which components we require from Solar Camper Solutions?
Cheers!
Hi, voltage dropped to this when it was really hot (30° and very sunny). Earlier in the day and later in the evening it went back up to around 14- 16 volts .Looking at that Display, if you have the panel in full sunlight, with no shadows across it, then the likelihood is that the panel is failing and probably needs replacing.
How is the panel fixed to the roof? Any photos of the panel?
Thanks, I’ve already chatted to Roger via email.
