Non-Cali - One for the Electricity wizards
kurienp
kurienp
Newbury, Berkshire, UK
T6 Ocean 204 4Motion
I know some basics - if I connected batteries like in serial - 2 x 1.5 v serially I get 3 volts.
I connect batteries in parallel - 2 x 1.5 volts gives me 1.5 volts … but for longer.
What will this circuit below give me as an output (EDITED) as voltage?
For context - disassembled a 5 year old ~26000 mAh battery pack that had gone bust. It has 8 LG 11865 batteries, that I plan to replace with new LG 18650 batteries. Just wanted to understand the circuit before I go ahead and replace them.
This is what came out
Ignore that I miss read the battery spec
Thank you. Just updated my question - what would be the output as voltage?
No I got it wrong the original batteries are 3000mAh at 3.7v each, your new ones are 2500mAh each at 3.7v so you have reduced your capacity by a 6th
planning for the 3500 mAh ones ... so should have a slight increase in capacity.
... though - a new anker battery pack is available at ~50 GBP
8 new 18650 3500mAh will be ~55 GBP + ~50 for a spot welder to assemble. More expensive to repair/rebuild than buy a new one. But I shall rebuild as the spot welder can be reused.
On the question though - what would be the output voltage. with 1.5 volt cells the output in my last diagram will be 3 v?
So on the 18650 cells the info I have is - 18650s may have a voltage range between 2.5 volts and 4.2 volts, or a charging voltage of 4.2 volts, but the nominal voltage of a standard 18650 is 3.7 volts.
So approx 3.7 x 2 = 7.4 v - if all the cells in my last diagram are 18650?
8 new 18650 3500mA….
I think yes, you have 4 parallel pairs connected in series so 3.7 x 2 = 7.4v.
Isn’t that how the batteries in an electric car are connected so that if you floor the pedal there is enough current ?
All the others are right if they are 1.5V per cell, then the output of your last diagram will be 3.0V.
The jargon description of that pack is 2S 4P (or 4P 2S). Don't neglect to manually balance the cells before spot welding.
Agree with others, the output voltage will be equal to the number of batt cells in series x voltage of a single cell. In my experience it’s tricky soldering connections onto the ends of cells without damaging them (or getting a dry joint due to insufficient heat). But don’t let that put you off - but I’d fully test before enclosing the power pack in anything.
Here's a typical discharge curve https://cdn-learn.adafruit.com/asse...al/components_tenergydischarge.gif?1447976645
And it's worth reading these notes:
Lipo is always (reasonably) safe to use at the more conservative voltage limits. LiFePo4 is generally a better and safer chemistry to use in a vehicle and has higher cycle limits.
