If I remember correctly both leisure and the engine batteries get charged.Does the connection to outer energy by cable also charge the engine battery or just charge the leisure batteries?
Yes, but I believe the Starter battery might only be trickle charged, unlike the leisure batteries.Does the connection to outer energy by cable also charge the engine battery or just charge the leisure batteries?
I was thinking the same that it was trickle charge but when i have it plugged into the mains and i look at my tracker app i can see the voltage to the battery is 14.3 volts dropping down to 13.2 after a while.at the moment i dont have the mains plugged in and its reading 12.6vYes, but I believe the Starter battery might only be trickle charged, unlike the leisure batteries.
Why say "trickle load", when the manual says all three will be charged?Yes, but I believe the Starter battery might only be trickle charged, unlike the leisure batteries.
