I'm constantly getting pop up ads for it on my Facebook, so I assume so.What a great idea. Wonder if it’s available in the UK?
How do you find the Joolca? I’ve been considering one.
It doesn’t seem to be listed on the Joolca UK website, but here is the link to the mounted ensuite on the Australian website.That looks perfect - but I can't find the same now on their website. Do you mind sharing the link please?
Titan is an Australian brand. I've subsequently replaced the Rola setup with a better Rhino rack tray, which is slightly larger, but even lower and lighter. I can provide the part numbers if you are interested.Plus I can't find the cool Titan Rola roof rack system you have - share your secrets ! : )
Yes please, my friend. I want your setup! Spent two great years in Australia with my T2 bay and surfboards - can't imagine how great it would be to have a Cali down underTitan is an Australian brand. I've subsequently replaced the Rola setup with a better Rhino rack tray, which is slightly larger, but even lower and lighter. I can provide the part numbers if you are interested.
Hello again - I’ve managed to find this rack in Germany - but there’s lots of size choice. Do you mind telling me what size you got please? And the fixings to the roof used? The 1500x1240 weighs 23kg so have you had any issues with max weight? Thanks!Titan is an Australian brand. I've subsequently replaced the Rola setup with a better Rhino rack tray, which is slightly larger, but even lower and lighter. I can provide the part numbers if you are interested.
There is only a single or double ensuite. The double will not fit. It is not fitted to the roof, but to the multirail. The fixings are custom made.Hello again - I’ve managed to find this rack in Germany - but there’s lots of size choice. Do you mind telling me what size you got please? And the fixings to the roof used? The 1500x1240 weighs 23kg so have you had any issues with max weight? Thanks!
The platform is a Rhino-Rack 62110 Pioneer 6 platform 1300mm x 1380mm sitting on Rhino-Rack RLT600 quick mount legs.Yes please, my friend. I want your setup! Spent two great years in Australia with my T2 bay and surfboards - can't imagine how great it would be to have a Cali down under
Sorry, I mixed up what you were asking about. I have provided the correct answer in a separate reply.There is only a single or double ensuite. The double will not fit. It is not fitted to the roof, but to the multirail. The fixings are custom made.
Thank you I've found the one! So 1300 is the width - I might get the next size 1430 x 1300 as I have longboards, canoe etc. Amazing.Sorry, I mixed up what you were asking about. I have provided the correct answer in a separate reply.
Actually, the width is 1380mm. I use the shorter platform because I Mount a solar panel in front of it. However, I have also bought roof racks which use the same RLT600 legs, so they can be used with the platform or instead of the platform, but on the same quick release base. This can cover longer items like surfboards, kayaks, etc.Thank you I've found the one! So 1300 is the width - I might get the next size 1430 x 1300 as I have longboards, canoe etc. Amazing.
