Fuse Board Diagram Driver side in Cab
Little owl1963
Little owl1963
Walsall West Midlands
T6.1 Ocean 150
Has Any one Got a diagram for what each fuse is for on the California Ocean T6.1 please.
Have you checked the Resources section of the Forum?
If you want a definitive fuse diagram for your vehicle then either approach your Dealership or set up an account with the VW Erwin website , and pay for a 1hr subscription and download the fuse diagram for your vehicle.
Yes looked at resources , not a definitive diagram .
I want to install nextbase dash cam , need to either use 2 x Fuse taps or go into spare holders ?
Need a red VCC+ always on
Also ACC on yellow wire , only when ignition on .
Any idea best location within board to connect too ?
Surely someone on this forum has a detailed diagram ?
I will contact my dealer also
Just use a Multimeter to check which fuses are live only with ignition On.
This post should help you locate switched and always on terminals for your dash cam installation.
Thread 'How to hard wire a dash cam T6.1 Ocean'
https://vwcaliforniaclub.com/threads/how-to-hard-wire-a-dash-cam-t6-1-ocean.53206/
See your image with white area outlined for fuses switched by ignition. The poster I linked used the 7.5 amp fuse as switched supply
And in the lower row outlined in red the right hand 10amp fuse for the permanent supply.
Your photo edited
Thanks very usefull , the fuses you refer too any idea what things they control ? ?
Also looks to be lot spare fuse spaces in board , would it be better option go into a spare slot of its own ? If know the correct spare slot ?
This guide (scroll down to find fuse box C interior ) covers all fuse options (many of which will not be present in your vehicle)
Fuse F42 ( 7.5 amps ) covers many items so read description carefully before pulling to use a tandem fuse holder and make sure ignition is off.
Fuse F52 is the tyre pressure monitoring system. (If present) the one shown in the dash cam post is actually F53 that is used as permanent live.
I do not think empty fuse ways will work with a tandem insert (anyone who has used successfully let the OP know)
