Andresz
- Messages
- 521
- Vehicle
- T5 HighTop
Hello
I recently followed an advice of my colleague to replace coolant pump in my 2007/ 86000km California 2.5l TDi engine.
The colleague has his 2006 Multivan engine completly destroyed during his vacation trip to Turkey. Not a pleasant vacation afterall.
Apparently (he learned about it afterwards) up to 2006 the coolant pump is very volnurable. VW recommends replacing it after 80000 km at the latest. His Multivan was 106000 when broke.
The fault is immediate, the engine gets broke before you manage to stop it. Damage is catastrofic with valves and pistons broken.
Following his advice and bad experience I replaced the pump in my California. You can see it on the image attached. There is the leak already commencing, causing the trace of rust visible.
The new pumps are reinforced. At least the propeller is metallic. But there are other modifications done, I heard.
Take it under consideration if you own a pre-2007 2.5l van.
Regards
Andrzej
P.S. I do not know why I cannot post it in "Servicing and Recalls" topic ?.
Regards
Andrzej
