4 Motion
sleepyjoe
sleepyjoe
Drymen, Near Loch Lomond, Scotland
T5 SE 180 4Motion
What's wrong with my 4 Motion rear axle diff-locks? :crazy
Can anyone shed some light on what is wrong with the diff locks on my 2010 facelift 4 Motion. Pushing in the dash button used to engage the locks if travelling at slow speeds <= 40 mph, showing locks were engaged on the display. I have only just discovered (just when I needed the diff locks to work) that they are inoperative. :headbang
Any suggestions welcome
Guessing that the display does not illuminate now when you push the button when moving? What happens if you push the button when you are stationary?
cheers
Thanks guys
Same thing, just seems to be dead. I know that locks not working when I got stuck in some boggy ground and noticed that only the sliding rear wheel turning. :sad
You will have to take it to a main dealer to have it diagnosed. Have only had one 4motion issue with T5's and that was the vacuum valve that had burnt out. But, this was used daily on a farm and had had heavy use.
Let us know how you get on
cheers
Having pondered on this problem and thinking about what Andy said about fuses :shocked , I went back to the fuse box and examined the contacts on the back panel. Lo and behold, one set of contacts was pushed back slightly with the pin of the fuse barely touching. A quick tug with a small spring hook and I now have working diff locks. :bananadance :thanks
Thanks everyone for the suggestions/help :hello
Yeah excellent, always worth checking the simplest, cheapest thing first !!
