mainy
Guest User
Can someone please advise if a T5 Cali 5th seat will fit in a T6 Cali? We would like an extra seat for occasional use and have seen a T5 seat but not sure if it will fit? Appreciate your help, thanks
Yes, I have bought one, all the location brackets /fixings are identical to the T6 seat just different coloured upholstery. Does your Ocean have the three floor rails that are required to fit the seat, the four wheel drive version only has two rails.Can someone please advise if a T5 Cali 5th seat will fit in a T6 Cali? We would like an extra seat for occasional use and have seen a T5 seat but not sure if it will fit? Appreciate your help, thanks
I know it's going a bit off topic but I'd be very interested in a review from someone with this fifth seat set up. I've missed our SE ever since we sold it. We now have a very practical Beach because we need the extra seats etc. However in the not too distant future an Ocean with an occasional extra seat might be a possible option.Yes, I have bought one, all the location brackets /fixings are identical to the T6 seat just different coloured upholstery. Does your Ocean have the three floor rails that are required to fit the seat, the four wheel drive version only has two rails.
Thanks Andy,We have had an SE for 4 years & have camped in it with varying numbers of kids.
The deciding factor is probably how often you are going to use it. We found the cali worked well as a 5 seat car with occasional use as a camper.
In car mode you either leave the rear shelf & mattress at home or stand it up vertically in the boot & slide the rear seat back an extra six inches to make proper leg room for the rear seat.
If you don't, you need one kid with no legs & not need access to the undersea draw!
It does however let you separate the most troublesome child & put them in isolation, & as a car with 5 comfortable seats with everyone spread out it works well.
For use as a camper that middle seat really does get in the way - you cant make up the bed with it there, open the under bench draw easily or put up the sliding table. On the other hand you can fold it down & use the back as a table.
So for overnight stops you need to get the seat out & put it somewhere & of course put it back in when you need to drive anywhere. Its a relatively heavy awkward lump to move around. But if you tend to park the van up for a few days add on an awning etc & walk / ride bikes it works well.
Cold wet evenings camping with 5 people and only 4 seats in the van can be challenging!
If the kids are little, I would consider making a shorter rear shelf - a foot shorter would let you leave the seat in, & still leave you a surprisingly good floor space along side it to access the kitchen. If its not needed, leave the middle seat head restraint at home, saves a bit more space.
To summarise - for 5 as a camper for a weekend its fine, for longer stays in one place it fine, but not so good if you are more the 14 sites in 14 days type of person.
We have tried it with 6 ! with 2x 5th seats - not to be recommended but just about doable.
Well in the end it's all down to personal circumstances. At the moment the Beach fits our needs perfectly but I can see the day when our needs may have altered sufficiently to make the five seater Ocean an attractive alternative.It sounds like it could work well for you especially if the camping & needing 5 seats never clash.
It depends what you think the extra versatility of a beach is.
For me an SE is ok as an occasional wardrobe transporter from ikea etc & even with the kitchen there its bigger in "Van Mode" than most cars, but the kitchen does stop me using it as a builders van which is a good thing.
I didn't want 7 seats, we have a 7 seat car for that, I didn't want it for the dump run - I have a trailer for that. If we had a beach all the camping gear would have to stay in it as the garage is already full & if its got to stay in the van why not have it as a permanent fixture.
I don't know what I would do with the extra empty space in a beach, so it seemed silly to deprive myself of a fitted fridge, cooker & sink just to get some extra space which I would only fill up with a fridge, cooker & water containers!
We have an Ocean with 5th seat. Leg room isn't great but if you need to carry 5 it does work. very heavy so not something you'd want to move in and out routinely unless you are strong or want to save on gym fees. It seems to be the best value optional extra from VW.I know it's going a bit off topic but I'd be very interested in a review from someone with this fifth seat set up. I've missed our SE ever since we sold it. We now have a very practical Beach because we need the extra seats etc. However in the not too distant future an Ocean with an occasional extra seat might be a possible option.
It should but you might find access to the rear two seat bench a major issue and even more important egress from it in the event of an accident.Perhaps a Beach two seater bench might fit the existing rails?
True, however the bench could be close to the front seat backs as the occupants are small children with short legs. It would be pretty heavy to lug in and out too. I may be better just to have a third rail fitted and use a 5th seat.It should but you might find access to the rear two seat bench a major issue and even more important egress from it in the event of an accident.
I'm not aware of anyone trying this. Still if the occupants are only small then it might work.True, however the bench could be close to the front seat backs as the occupants are small children with short legs. It would be pretty heavy to lug in and out too. I may be better just to have a third rail fitted and use a 5th seat.
Tom
Thanks Andy, very helpful, now back to fitting a third rail.If you do a search, this has been discussed before, the two seater beach bench is almost identical to the ocean bench. I have previously tried & its not possible to put two benches in at once and have a safe means of access to the rear one.
The bench is much deeper than the 5th seat & therefore uses a lot more floorspace. to make enough room to squeeze into the rearmost bench the front bench has to have its front edge touching the backs of the front seat so no leg room at all.
The access into the back bench ends up being less than a foot wide through the side door, with that also being the only exit route in the event of an accident.
Recent comments on this subject go into some detail, see belowThanks Andy, very helpful, now back to fitting a third rail.
Tom
