Chainline
- Messages
- 232
I have read around the solar and offgrid threads and plotted LiFePO4 replacement of AGM etc but have concluded two things.
1. I would like to use solar like an Ecoflow/Jackary folding panel to charge the current OEM battery (not great as it is)
2. To go with this, assuming it is not quite enough or I want back up - get a ‘power station’ as not currently brave enough/don’t know I will need to go with wired in inverters and second leisure battery’s
To this end, and not being able to find the thread with the pic of a German van who fitted an (MPPT?) on the battery under the bonnet directly connected to the leisure battery (LifePO4 in his case) and just plugged in his (mobile folding) panels while parked/bonnet closed
Is anyone able to advise me, or recommend a company that could replicate this, what equipment I need to fit a similar accessible solar plug in point (I would like to know what they are, Is it just an MPPT in this case) And where I can fit it (under bonnet or in rear of vehicle) as I have seen lots of clever ‘off grid’ installs with a mass of Victron kit in the garage but the debate can get confusing as it often also centres on Li-Ion battery tech and its impacts.
On the (MPPT or charging interface unit) It is not clear to me if I can fit such a unit in the garage or if this is a good idea (wiring/second leisure battery charging cable specs, all this I understand) but I actually think that given where VW have fitted the leisure battery (right or wrong) an under bonnet next to leisure battery solution allows the van to remain closed and locked yet still benefit from the solar. However I am open to advice here.
Any help/kit list/installer recommendations gratefully accepted before I drop several hundred pounds on some 200 - 400w panels and portable lithium
