R
RobinGambles
The outlet from the waste water tank on our Cali T6, or the opening into it, is blocked. The lack of flow in the outlet pipe has been building up for a while. Even when bought nearly new, 3.5 years ago, the flow wasn’t that fast but adequate taking about 5 or 6 mins to empty. Coming out of lockdown I wanted to see how it was and put about 18 litres of water through the basin into the tank. Its trickle is so slow, and no more than drips, so that over the last 24 hours a washing up basin (whose base is 225 x 275 mm) has only filled by 3.5 cms.
I’ve gently pushed a thin flexible plastic coated net curtain support wire up the tube from below to see if I could locate and clear the blockage. The first time after meeting some slight resistance at a couple of points (as if there might have been a slight bend or whatever) I got it as far as c95cm up the outlet tube. But nothing dislodged or improvement of any kind. I tried again later but at 42 cm the wire hit hard and solid edged resistance (ie not sludge or whatever). A second attempt gets to the same resistance point and no further.
Has anyone had experience of this and what is the best way to deal with it?
