P
Peter Guiton Cali
Only at Heathrow Long Stay when down under.I believe @WelshGas uses a pedal lock
When I use the pedal lock the keys are thousands of miles away from the van, in Sydney NSW.It seems that the van cannot be taken without the key unless it is picked up and towed away, (at least there are no known, confirmed, instances of this ever happening) and i suspect you would keep the key to this pedal lock with the keys to the van, so probably not worth it.
