Erbster
The table is a well documented issue and most of the time has not been correctly stowed (takes a fair bit of practice to get it right, my wife still can't get it right after 4 years of ownership lol).The kitchen table on an Ocean/SE rattles like crazy as they are only locked in the stowed position adjacent the hinge by a flimsy plastic catch, leaving the mass of the depending lower 3/4 of the table free to move. Stuff a tea towel or something either behind the table to wedge it against the seat or between the seat and the table. Haven’t worked out which is best. Also the tap rattles on the glass worktop if not pushed down fully. The awning also rattles but that’s cured by tightening v tight with the winder crank.
Sound does travel from unusual places in the California.Hi,
Just another quick one to check. I was getting a really annoying squeaking / rattling sound that I could have sworn was coming from the sliding door area. I faffed about with the blinds, pushed and pulled the interior trim, moved the bed back and forth etc, but with no success. It turned out to the the deck chairs stowed in the tailgate rubbing on the plastic supports........ Easily fixed by some non slip matting stuff.
Cheers!
Does anyone remember the old VW Gold ads with girl with the squeaky ear ring.... the whole premise of the advert was that VWs are solidly built and don't rattle!!!! My VW CC used to rattle, my current VW Torag has a few annoying noises and my beech has rattle from the awning and the speaker grill on the front dash needs pushing into place every now and then to stop it rattling. It seems they all rattle.
The awning rattle which is quite common is usually the arms that meet in the middle. I’ve put a couple of rubber bumpers under where the arms rest on the casing - the self-adhesive type they use on double glazing are fine. This cured my awning raffle problemThey do rattle. But they shouldn't. If it has an Awning on then it's probably that. I never did get to solve the rattle on my Awning. Also could be a number of things like the tables. Not clipped in or missing some pads in the door. Bang the Awning when stationary with your hand. See if it's that. If so get them to swap it. I'm assuming it's empty of camping stuff like beer in the fridge and bottle openers in the drawer. Good luck.
Not quit correct. There should be a slide clip/catch that holds the bottom of the kitchen table, but you need to push the table towards the kitchen unit as you slide it into its storage position. There should be no need for a towel or anything else to stop the table rattling, just make sure it is stored properly.
