Good morning,
I checked all the batteries yesterday and the battery in the back of the camper was almost empty. I then connected the power cable, but after a while a message "cable?" appeared on the display. and there was a ping ping ping sound. It stopped a moment later and then came back.
I then retested all the fuses, including those under the driver's seat and under the hood, all of which were intact.
The sliding door only responds to the remote control, but then I only hear a tap and nothing happens.
There is no response at all to the controls on the sliding door itself, it seems as if there is no power to the door.
I'm just curious what the cable that is at the roller at the top of the sliding door does, is that a sliding contact?
Here is also my last VCDS check, perhaps you can make something out of it, thank you very much in advance for your responses and I hope that I will find a solution today.
Sunday,19,May,2024,18:59:29:08012
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 24.5.0.0 (x64)
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZ6H131723 License Plate:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ6H131723 Mileage: 309930km-192581miles
Address 01: Engine Labels: 070-906-016-BPC.clb
Part No SW: 070 997 016 M HW: 070 906 016 CG
Component: R5 2,5L EDC G000AG 2605
Revision: --H02--- Serial number: VWZ7Z0F3862428
Coding: 0001075
Shop #: WSC 43253 001 1048576
VCID: 244D19C5E4C4B3B607-513C
VINID: 9E60AAAAA1D8A866010C11C20C0EA83B4A
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09K 927 750 K HW: 09K 927 750 K
Component: AQ 250 6F 0864
Revision: 00H36000 Serial number:
Coding: 0000072
Shop #: WSC 02744 790 00000
VCID: 3D7BCCA1676EE27E68-515A
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP-F.lbl
Part No: 7H0 907 379 L
Component: ESP FRONT MK25 0203
Coding: 0006187
VCID: 3E79CBAD6A68F96671-5120
Address 08: Auto HVAC Labels: 7Hx-907-040.clb
Part No: 7H5 907 040 C
Component: CLIMAtronic T5 4221
Coding: 0011030
VCID: 2B5FF2F9891A7CCEC6-5120
Subsystem 1 - Part No: 7H7 907 049 A
Component: Display_2_ClimaT5 X 0307
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 AA
Component: BORDNETZ SGVER 1.0 2001
Coding: 0000358
VCID: 71E320916BB6561EBC-5120
2 Faults Found:
00910 - Indicator Lamp for Emergency Flashers (K6)
007 - Short to Ground - Intermittent
00078 - Battery Cut Out Relay (J7)
Address 0B: Sec. Air Heating Labels: 7H0-819-002.clb
Part No: 7H0 819 002 M
Component: Luftstandheizung, D 0428
Revision: 00052428 Serial number: 0097616
Shop #: WSC 00000 000 00000
VCID: 3065E595A03C1F16F3-4B32
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 11 AIRBAG VW61 0R 0003
Coding: 12593
Shop #: WSC 02744
VCID: 27570EC9C5F258AE22-5120
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 C
Component: Lenkradelektronik 0006
Coding: 00119
Shop #: WSC 02744
VCID: 3163E091FB36161EFC-513C
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H5 920 872 E
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 05112
Shop #: WSC 00106
VCID: 356BD4810F5E3A3EA0-5120
WV2ZZZ7HZ6H131723 VWZ7Z0F3862428
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 18: Aux. Heat Labels: 7H0-819-008.clb
Part No: 7H0 815 071 E
Component: Standheizung 0207
VCID: 2A51F7FD86E065C63D-5120
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 02744
VCID: 70E5259530BC5F16B3-5120
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C2L Komfortgerát 0004
Coding: 00073
Shop #: WSC 02744
VCID: 3261EF9DFE302D0685-4B00
Subsystem 1 - Part No: 7H1959801A
Component: Tõrsteuer.FS KLO 0203
Subsystem 2 - Part No: 7H1959802A
Component: Tõrsteuer.BF KLO 0203
Address 76: Park Assist Labels: 7E0-919-283.lbl
Part No: 7E0 919 283
Component: Parkingsyst. T5 T5M 801
Coding: 11127
Shop #: WSC 02744
VCID: 6CDD31E51C94BBF68F-513C
Address 77: Telephone Labels: 7H0-035-729.clb
Part No: 7H0 035 729 F
Component: CIB PAH HW 204 SW 0309
Coding: 0000364
VCID: 2F67E6E9BD0200EEEA-5120
Address 78: Slide Door, Right Labels: Redir Fail!
Part No: 7H0 959 243 J
Component: Schiebetuer-SG 404 0320
VCID: 3973D8B17346DE5E44-5120
End-------------------------(Elapsed Time: 05:36)--------------------------
