Can I fit a small sofa in my California?
ThisIsChristoph
ThisIsChristoph
London
T6.1 Ocean 150
Hi all. I'm currently (far) away from my beloved 6.1 Cali Ocean and am trying to figure out whether I can fit a small sofa inside it, with or without taking out the 'parcel shelf'. Could someone help me figure out whether it'll fit please? I'm keen to help a friend transport his sofa but don't know whether I can say yes or no as I'm away from home for several weeks and can't yet my tape measure out...
The sofa's measurements are:
153cm long
60-70cm depth
61-68cm high
Thank you very much!
If you make the bed up it should slide in through the rear door on top of the bed. Or shelf out and slide seat forward all the way (with the stopper removed) might do it.
Agreed - with the bed made up the opening under the rear overhead locker & the top of the bed is roughly 1m wide and 700mm high
This is great to know - thanks so much. So I could fit the sofa in, but no passenger(s) in the back, if the bed is unfolded/flat, right? Good call about the stopper, I've been meaning to look into that for a while now: this might be the opportunity to remove it.
