SimplyDubs said:I use one supplied by British Gas... Small and standard.
Not camping specific but does the job.
Dorchest said:Hi all
Are carbon monoxide detectors really necessary in a Cali if you open windows/door for ventilation when cooking?
I always ventilate the Cali when using the hob and the ancillary heating unit is fitted underneath with external exhaust I believe so do I really need a carbon monoxide detector?
Surely, VW would fit one as standard if it was really necessary and DIY fixing in the wrong place could surely make one useless anyway?
Any views on the necessity or not would be interesting?
Mike
Dorchest said:Hi Tim
I'm very safety conscious too but fitting one could give a false sense of security. I did a google search before posting and some people were recommending putting the detector as high as possible, thinking the carbon monoxide would rise like heat, whereas someone else said it should be below your head height when sleeping as carbon monoxide is heavier than air so will gradually fill the space from the ground up - so in theory, if you're sleeping in the seat-bed, you could be 'brown bread' before the alarm goes off!!
I like fresh air even in cold weather so I ventilate the van a lot - trying to keep the condensation down too - so I'm hoping carbon monoxide won't be a problem.
A good design feature on the Cali that would have been useful would be closable vents around the vehicle so it can be ventilated securely without leaving windows open. Rear closable vents would be especially useful so that the van could be 'aired' just by driving with the front windows open.
Mike
Dibz said:One question on this. I thought the heater is mounted outside the vehicle and is a blown air heater, is this not the case? I.e. the heater is under the van which heats an exchanger/chamber and draws fresh air from outside through the exchanger to warm it before it comes into the van. Completely separating and isolating the heater/burner from the warm air that comes into the van preventing fumes/exhaust/CO from being blown in by the heater, so you only get warm/hot fresh air in.
If this is the case it could help in CO detector placement as the only source would be the hob, and if you always ventilate when cooking, the risk should be small.
