Cigarette lighter fuse
chrisswash
My USB adapter fell to bits when I plugged it into my cigarette lighter socket and shorted it out and blew the fuse. Now none of the lighter points work. I have checked the fuses under the passenger seat and they are ok. Does anyone know where the cigarette lighter sockets are fed from.
Chris
2005 California Comfortline 174
I think its in the fuse board under the cupholder not sure which one though
It should be under the left hand seat. Access is difficult, you probably need to unbolt the seat to move it slightly away in order ti check the fuses properly...
Andrzej
Hi
In order to find the cigar lighter fuses I tested all the fuses under the seat. The cigar lighter fuse is the blue one (15 amp) which is located to the right hand side all on its own. It also sits at 90 degrees to all the other fuses so its easy to find. This relates to a 140 2014 Cali.
Hope that helps.
Mike
