Leo Sande
At the speed around 70-80 (km/h) the DSG puts in gear D6 and immediately sets the rpm to between 1.1-1.2 with result that the engine chokes, produces an annoying sound and usually even vibrates, felt in the entire car. Power is also temporary lost. (Sounds to me as very bad for the engine with this too low rpm.) I spoke/complained to VW about it, and got later an answer from a technical service that the combination gear and rpm cannot be altered and is programed at the fabric for “optimum performance and fuel-consumption”. I was left with that.
There are - as far as I understand - three remedies for this:
- “Kick-down”, putting the throttle to the bottom. This will change to one or several lower gear(s). A procedure I dislike and have difficulties performing smoothly.
- Switching to S-drive. Not realistic for a temporary gear adjustment … though, can be used on country-roads, often with speed limit 70-80 (km/h) during long distance … then with higher fuel consumption.
- Quickly switching to manual gear-shifting (Tiptronic) and setting a lower gear, than shifting back when the speed is over the critical point. With constant road limit to 70-80 (km/h) it's not possible to go back to auto-gear. Then the car is in fact as one with manual gear-box … and that is not what one payed for.
