P
Passatwind
Hello there Cali lovers,
Many of my 12 volt things no longer work.
It started that I had to keep resetting the clock in the control display, but now, for example, the tap and the refrigerator no longer work.
I have checked all fuses and they are all good and I measure 12 volts on all fuses.
Is there some kind of main fuse somewhere that provides extra protection for the 12 volts?
I've been having a lot of trouble with my sliding door (see my other post) and now I have this on top of that.
Does anyone of you know what exactly the relay in the attached photo does? I suspect this is also the problem with the 12 volts because it was very hot.
Thanks you all
Thanks you all
