sidepod
- Messages
- 6,852
- Vehicle
- T4 PopTop
.....still can’t find the external temp sensor?
heater is switch off via the thermostat in the coolant loop
Mr C is confident it’s the one behind the bumper?
You’re quite right and given time that’s what I’d do. My overhead control panel isn’t displaying the outside temp so I’m hoping to fix that.
Did you manage to find which fuse feeds the heater?
Off on hols Saturday so it’ll probably be after that when I get in amongst it.
Lucky guy heading to Austria!!! If you have the time, its worth getting the coolant heater working. However, when I work dayshift, I leave home at 06.40 and this winter many mornings were below 4.0c
I thought the coolant heater would give a lot of heat very quickly, however it just heats up a little quicker than normal.
I presume its working correctly.
Its a ten mins drive to work, so after a few mins i can feel warm air & usually the engine is up to temp by the time I get to work.Depending on the kind of driving your doing the coolant heater should have the engine up to normal running temperature within 10 or so mins. If it’s not working, unless you have a fast A road blast, the engine is unlikely to get to running temperature for a substantially longer time. If yours fires up below 4C as it should then it’s probably doing its job.
I believe an additional timer can be got to allow it to be used when the vehicle is parked, the kit has additional pipe work and pump, etc.
veSounds about right. The timer kit for the coolant heater - not really worth the expense if you already have the air heater fitted. In fact if you don’t have the air heater you’d be better getting that fitted as it’s much more efficient at heating the passenger area.
