Display problem
Muffutd
Muffutd
West Midlands
T6.1 Ocean 204
Hi all
Currently in Luxembourg after a 12 hour stint from uk and so you would imagine the leisure batteries would be showing 60+ hours - all indications are that everything is ok but displays shows only 24 hrs and this is plugged into ehu ?
Am I being daft or anything obvious that I am missing or is just a faulty display reading
Your help / thoughts will will be appreciated
Search is your friend but top level explanation is the time remaining is just a calculation based on voltage vs amp draw. In the main. Don’t worry about it. It will go up and down depending in what you are doing in the van. Did you put max charge on when driving?
Thanks for response - Yes I did pretty much all the way - so had a good 6-8 hours - it’s always showed 60 hours previously so just a bit surprised / confused as to why it’s showing what appears to be low - it is difficult to have confidence if we’re only reliant on battery
