Drive away awning connectors
D
Dave Wickham
Newcastle upon Tyne
Hi all
Does anyone know if you can buy an awning connector strip 8mm to 6mm (like the Kador product attached). I can only find 6mm to 6mm or 6mm to 4mm. The awning rail on my T6 is 8mm diameter. 6mm fits but a bit loose. Very much appreciate your guidance.
Hi all
Which awning rail are you referring to as 8mm?
You may need one of these from the club shop:
VW T5 T6 California plastic slide in connector insert (C – channel) to attach Drive Away Awnings Etc
