NickHX
So currently in Portugal on a six week trip. Halfway through central Spain, all of a sudden the engine shudders, the ESP warning light comes on along with the tyre pressure error, and we lose power on the autovia. We pull over, check the tyre pressures, restart the engine, the error lights disappear and everything seems fine again. One hour later we get the same problem, so we decide to go straight to the closest VW van center in Valladolid. The friendly chap there does a scan and basically tells us they are ignorable errors and that we should carry on with our trip!
We managed to get to our destination in Portugal more or less alright, but yesterday after driving 20 minutes for my Father’s Day lunch, the van then has the same failure, but this time accompanied by the engine coil error (solid, not flashing). It took a few minutes to get the engine started this time, and then we had the failure about four times over 5km to get to our lunch spot.
Called European breakdown and got the van towed back to our accommodation and now currently having the van investigated by the local mechanic. His scan has found a variety of errors which I can provide later, but the interesting thing we found is that when driving in D mode, the error happens within a few minutes, but putting it in Sport and the error never comes up at all. The mechanic told me that S disables notifications from the ESP sensor, which to him indicates there is nothing wrong with the engine (thank god) but is ‘definitely an ESP issue’
Looking on the forums, our error seems closely related to this issue:
But this error indicated that there was a TPMS sensor, but I was under impression that there wasn’t a dedicated TPMS sensor but rather it uses the ABS system to detect low pressure.
So after much rambling, my question is, is this enough information for anyone to help us figure out a path out of here. Is this likely to be a duff ESP sensor.or potentially something else? We are a few years out of warranty so don’t really want to go to VW for this, but if they’re the only people that can resolve this then so be it.
For context, we’ve had spurious occasional type pressure errors ever since we’ve had the van (over three years) so to me this sounds like some kind of faulty sensor issue. The van is a 2016 4motion 204ps.
Warning light. Advice
Coming home from Winchester today Yellow Engine warning light came on. AA reset light at home. following faults recorded PIBD600 - combustion chamber pressure sensor -sporadic fault (cylinder 3) PO1Z100- TPS signal improbable - sporadic faults deleted and saved - advised visit dealer if...
vwcaliforniaclub.com
