G
gatvol
- Messages
- 535
The illumination on my rev counter is much dimmer behind the "3" at the top compared to the other numbers. This is clearly visible both during the day and at night, regardless of the level of illumination I set.
Is this a fault please, or do others have the same issue? It is a 61 plate so still under warranty
If it is a fault, has anyone had this sort of thing fixed ? If so, was it a straightforward job or did the dealer inflict collateral damage, scratch things, dirt behind the glass, do you wish you had left well alone etc?
I once saw a merc sl that had been butchered by a repair shop when it removed the plastic glass in front of the instruments; and it has made me very wary of opening this part of a car up for minor warranty issues. There must be some honest, reliable garages out there, but I have seen many cowboys too.
. To my mind this is obscene when what we are doing here is fixing a bulb.
