California_Ocean
Requirements:
Around 300W Solar
Car Wash friendly (no curly cables)
Components:
Hess 320W Solarträger ... https://shop.automobile-hess.ch/pro...ranlage-beim-vw-t5-t6-california-320-w-anlage
Collected from the manufacturer during a holiday in Switzerland - saved delivery costs.
Phaesun Mare Flex 155 Solarmodule x 2 .... https://www.esomatic.de/solarmodule/semi-flexible-solarmodule/310423.html?number=310424
Scanstrut DS-H10 grau Kabeldurchführung .... https://lepper-marine.de/Scanstrut-Kabeldurchfuehrung-horizontal-DS-H10-grau/1053-00164
250V DC 2P Low Voltage Miniature Circuit Breaker Solar Energy Switch 32A .... https://www.amazon.de/gp/product/B07D27Z8GC/
Viko Surface-Mounted Small Distribution Board für 2 Module ... https://www.amazon.de/gp/product/B08VMR2DWW/
Victron Smartsolar MPPT Laderegler 100/30 .... https://www.online-batterien.de/shop/index.php?a=1013786
Total cost + sundry items around €1350.
Solar panels are glued with Sikaflex to the Hess panel which is bolted into the roof-rail slots.
Solar panels are connected in series on the roof and sealed in glued heat-shrink (with a XT60H connector should I ever need to remove the panels).
Cable goes through the roof via a Scanstrut marine cable gland (100% Waterproof) and the cables are routed alongside the wiring for the LED lights in the pop-top headlining - they are invisible inside the van.
Solar isolator and MPPT are mounted in the top of the rear cupboard.
MPPT is attached to the earth point on the rear left behind the 240V RCDs at the bottom of the cupboard.
The +ve is fed to the second battery and protected by a 40A MIDI fuse.
Best daily yield so far is 0,75kWh and the fridge has run 24/7 for 3 weeks with no external hook up ... and it's been through a car wash a couple of times too.
Very happy with the result.
Around 300W Solar
Components:
