N
nottsknight
- Messages
- 44
- Vehicle
- T5 SE 174
Is it better to leave the drain valve open or closed when the van is not in use. I have heard that if you drain all the water from the tank the rubber seal at the base of the tank perishes. Conversely, if the water is left in during freezing conditions the tank will crack. Either way sounds a problem. Any ideas?
