![Anthony1](/data/avatars/m/0/683.jpg?1697297324)
Anthony1
Too young to be old
- Messages
- 1,198
- Vehicle
- T5 SE 180 4Motion
As long as they have the same output and connection - Yes.I may need to replace my fresh water tank pump.
The one from the shop cost £40 (including postage)
Does any one know if these might also work?
At £14.78 and £10.98 repectively - Free Postage, delivery tomorrow.
Thank you.As long as they have the same output and connection - Yes.
The shop sells the VW oem part so that will definitely fit and have correct output.
Thank youLooks like it
You have the old pump out. -tve to -tve of battery. +tve to one end/blade of the fuse and touch other end/blade of fuse to +tve of battery. If pump runs and fuse doesn't blow then pump OK and you have a short in the vehicle circuit. BUT if fuse blows fit new pump.I checked the pump, in the van, this moring and still nothing.
But one of the 5amp fuses under the passenger seat had blown - that's the 3rd one to go.
There has to be a short somewhere. Someone suggested I test the pump with a five amp fuse (away from the car) to see if the pump's is doing it.
I will try that, if I can. Bit tricky though.
