CaliforniaCylus
The front blinds used to close and attach together in the middle. After a few weeks of use in total, there's now a cm gap between the two handles.
The problem appears to be the spigots which under heat and tension have started to a) Bend a little and b) pull out of the had handle slot on one side
Does anyone know if you can replace the spigots (I will try under warranty but that's a faff) or even the slide-on handle.
We've secured them with a bulldog clip in the middle which at least stops the risk of an uncontrolled rewind of the blind since the "bent" spigots no longer stay firmly in the fold-down flaps. Picture below.
