Halfords stock this£44.99pVery interesting! I was just about to order a Garmin dashcam from Halfords and pay for the hard-wiring (£35). If this works, I'd prefer it to letting Halfords loose on my Cali.
Halfords refused to fit mine, said the california was to complicated so i did it myself.Very interesting! I was just about to order a Garmin dashcam from Halfords and pay for the hard-wiring (£35). If this works, I'd prefer it to letting Halfords loose on my Cali.
Thinking of ditching a Hardwire kit for this. As sourcing a constant power from dash fuse box is a bit tricky on T6.1 ( some fuses are timed power so mine is off after a couple of hours ).
Credit to Halfords for honesty! Better than having a go and buggering it up!Halfords refused to fit mine, said the california was to complicated so i did it myself.
They said they couldnt find an unswitched supply near the top of the screen and weren't prepaired to spend time finding one elsewhere as the only got £25.00 for the job. Their words not mine.Credit to Halfords for honesty! Better than having a go and buggering it up!
Was it the OBD or fuse connection?
You got off lightly! The thought of them poking around with the control panel wiring is worrying.They said they couldnt find an unswitched supply near the top of the screen and weren't prepaired to spend time finding one elsewhere as the only got £25.00 for the job. Their words not mine.
Just a thought….. does the OBD supply have fuse protection? (I’d assume so).I wired-up my Garmin dashcam to the OBD power supply today. Whole job done in probably less than 20 minutes with the USB cable tucked up into the headlining and down the A pillar rubber seal. Seems to work as advertised. I've set the OBD power supply to switch off after 10 mins from ignition off. I think if I park away from home I'll flip the swtich over to '24 hours' so the camera stays active. Feels like a much easier DIY option than messing with fuses.
As it's a Garmin product, I'm trusting it's designed and built properly - unlike some cheapo Chinese OBD power supplies on eBay which I wouldn't touch with a bargepole.Just a thought….. does the OBD supply have fuse protection? (I’d assume so).
I was thinking more about whether the OBD port that will be supplying the Garmin was fed via a fuse In the Cali. As you say the Garmin kit should be well made.As it's a Garmin product, I'm trusting it's designed and built properly - unlike some cheapo Chinese OBD power supplies on eBay which I wouldn't touch with a bargepole.
