K
KAP0902
Hi,
Took ownership of a new Beach Camper in May with High Beam Assist as an option, since the clocks change it has really been the first time to check this feature.
Reading the manual there is no description or mention of the 37 mph activation to main beam when lights on Auto/dipped beam, I mention this as there are posts I've read that clearly state that this does work. A few moans about it being at 37mph as too high though.
My issue is it doesn't activate at 37mph, it does work by moving the stalk to show the white 'A' symbol together with changing to main beam.
I do have an OBD11 device so I checked the settings in the module:
37mph parameter is loaded and can be altered if desired.
Light Assist is ticked (infotainment)
Main Beam Assist Memory isn't.
Cleaned camera, screen etc.
Halogen Lights
I did contact VW Customer Service regarding the correct operation in case I'm missing something, Christmas 2024 will arrive before I get an answer.
So if anyone could please enlighten I would be grateful.
1. If on Auto/dipped beam should main beam activate at 37mph without doing anything else?
2. To me if I use the stalk, main beam will alternate due to camera sensing light etc for safety reasons.
Thank You
Halogen Lights
Thank You
