Correct,If it’s the same as my Cali t6.1, you just move the auto shift towards the right and can then select gears manually.
There is no clutch on a GC it’s a traditional torque converter automatic.VW order spec says that 8 speed Auto box is fitted which I'd assume to be the same/similar to that fitted to vehicles across various manufacturers - ie a computer controlled clutch operating system.
In time a gearbox remap may become available but the potential sales market may be too low for design investment currently.
Unusual to find Torque Converter still in use with demand for accurate emission control.There is no clutch on a GC it’s a traditional torque converter automatic.
I don’t know why anyone would need a remap, it behaves exactly how you would expect a decent auto box to.
For downhill engine braking it changes down with a very small tap on the brakes.
For going faster it responds well to throttle inputs to decide how many gears to change down.
Pulling away is far better than on an ocean with the torque converter cushioning the drive engaging so no sudden jerk & no wheelspin at greasy junctions.
If you don’t like the way it’s behaving there’s always manual mode.
Its not "still in use" its a new design developed specifically for the Crafter, I do prefer it to the Ocean DSG box - feels exactly the same as a DSG once on the move with none of slurring between gears that you used to get on old 3 speed autos, whilst it still retains that flexibility for very low speed manovering.Unusual to find Torque Converter still in use with demand for accurate emission control.
