Interior lights coming on after van shut an locked ??
Little owl1963
Little owl1963
Walsall West Midlands
T6.1 Ocean 150
Noticed this morning just the kitchen sink middle light was on and the 2 tailgate rear lights , although I locked van a day ago,
Strangely as well the middle sink light was going brighter an dimmer by its self ....???? All why watched outside with door locked,
Could someone clarify how lights should operate with regard to van locking irrespective of whether lights are manually put on or off ...???
I no when first unlock van lights come on automatically so assume when lock should go off the same ......?????
Any advise thanks .????
The sink light was constant going up an down in brightness by self ????
You have double-posted this at 6.30 and 6.27.
Two possibilities come to mind.: You keep your keys in your pocket and are accidentally engaging buttons or someone else has a key fob that's on the same frequency as yours. If you locked the van last night as you claim then there should be no light activity in the van today.
They are needlessly complicated on the T6.1 - The video might help.
Nightmare got worse control panel not working only thing get is German writing nothing else hook up does not work no yellow light on
Control panel frozen
He s another nightmare before xmas
There is a control panel reset that you can perform by pulling a few fuses (5-8?)- Might get you out of jail maybe. I'll have a search for you
edit: Here you go - Might sort you out maybe?
Google Translate says “
Mistake
operating system. You're welcome
Visit workshop “
Seem recall pump message coming up for tap said no water
Had not used tap as drained water out when frost forecast ??
If not using tap sure you don't need keep water in tank ??
