Interior lights - fuse keeps blowing - is bendy light the culprit?
K
katyjw
Cornwall
T5 SE 180
Hi, I have a 2006 SE, does anyone know if the upstairs bendy light is on the same fuse as the ‘downstairs’ interior lights. It’s a bit rubbish and flickers on and off, I’m no electrician but continually find the fuse blowing for the interior lights, sometime it lasts days, other times months before is blows again. Is anything else run if this fuse?
Thanks in advance for any info
@katyjw did you find solution? As I need location of fuse for bendy bed light
There are fuse diagrams/plans for the T5/5.1 in the forum Resources section.
NB: The position of the various fuses can vary within the relevant fuse box depending on Options etc:
But the size fuse, 5 or 20amps etc:, will be correct and it will be in the correct fusebox as detailed.
