Accessories For Sale Kampa Touring Air Technical Cotton RH Drive Away Awning - Brand New.
Lexlogie
Lexlogie
North Yorkshire
T6.1 Ocean 150
Bought for vw California and NEVER used as used old drive away awning and now sold the van.
This is the top of the range drive away awning from Kampa. The TC is to keep the inner temperature cool compared to nylon tents during higher temperatures and to make warmer during colder conditions.
Huge saving from New.
£600 inc ground sheet and carpet
HG4 (North Yorkshire )
This awning is a Right-Hand version designed for continental vans or VW California's (This can be sometimes known as an RSV Model)
The Touring Air TC is Kampa's best-selling driveway awning as it creates the perfect living/sleeping area for the side of your campervan. The Touring is quick and easy to pitch as seen in our Attwoolls Pitching videos, the whole awning can be pitched by one person within 10 minutes. The awning fits alongside your vehicle which means it maximizes your pitch space and allows you to face the way your van is facing. The inflatable beams mean it is quick and easy to pitch, making it an ideal choice for either short or longer trips away.
A 4 berth inner bedroom is included to accommodate sleepers inside the awning rather than the vehicle but there is still ample living room as well as an open canopy for shelter. With the optional extra of adding a footprint, carpet and lighting you can really make it a home away from home. The Touring Air has a large front canopy, giving protection from the weather and allowing you to open the front door even when it’s raining. Inside you will find a huge living space, with lots of windows to give you plenty of natural light and an excellent view. We would recommend you purchase the additional storm straps to get the roof tort and strengthen the awning in winds.
The Kampa Travel Pod Touring Air is designed to fit campervans with heights between 180-210cm, there are a number of ways to attach the awning, for example, using the velcro straps which are stitched in, throwing the included guyropes over the top or using a pole and clamp kit to fix it to a gutter but in our opinion, the best way would be by using a fixing kit into a rail.
Suitable for campervans with a rail height of 180 to 210cm
Technical Specification
Pitching Time 10 Minutes
Pack Size 74 x 48 x 45cm
Weight 29.45kg
Length 610cm
Width 280cm
Height 210cm
Attaching Height 160 - 210cm
Kador Length 250cm
Materials
Weathershield™ TC - All the protection of polyester material with superior comfort. high-quality Weathershield TC polycotton material allows the tent to breathe, reducing condensation and helping to regulate the interior temperature on hot days.
Sewn-in Groundsheet - PE 10 x 10 130 g/m² 10,000 mm HH
Standard 210cm Bedrooms
Secondary mesh on Front door
One Tunnel Door - allows access into the van without going through the awning
High-Vis guy-points around the tent and additional storm straps can be purchased (x2 packs recommended)
Toggle inner divider - Offers greater privacy between inner bedrooms. Roll away when not required
Toggled privacy curtains - Simple and quick to use, with two varying levels of opening
'Sleeptite inner tents' - Darker fabric reduces the amount of early morning light
Inflatable Frame structure - Allows pole free pitching, ensuring your tent is erect within a matter of minutes
All flysheet and groundsheet seams are factory taped - Provides watertight seal
Kampa's Weathershield TC - highly waterproof, durable and reliable fabric that will keep you dry and comfortable
Fully Sewn-in Groundsheet - adds to the comfort of your tent by providing a bug and draught free environment
Waterproof PE groundsheet
Open Front Canopy - the ideal amount of shelter for cooking under or storing stuff
Part mesh inner door - Allows ventilation, whilst keeping bugs out
Covered entrance - gives a sheltered entrance to your tent, which prevents rain from dripping into the living area
Bedroom pockets - conveniently positioned pockets for storing your essentials
Diamond Clear windows - Maximise light and visibility
High ventilation - Combine to create a comfortable flow of air through the tent, reducing condensation
Easypack holdall bag - Durable to take the effort out of packing your tent away
Reply
Report •••
V
VDubBUS
V
Steve.Cox
D
dave shemmans
D
Greyvanman
Lexlogie
Lexlogie
