Sorry Now Sold KHYAM SLEEPER DRIVE AWAY CAMPERVAN AWNING WITH GS & FIXINGS
Micka
Micka
Brentwood
T6 Beach 150
Used from new twice for weekend breaks last year but decided its too large for our needs. Comes with one 2 man inner tent (single adult really but also bought an aftermarket one which I'll throw in too), ground sheet and the figure of 8 strips and beaded strip to attach the awning to a campervan. As you can see ours is a T6 and the awning attached directly to the wind out awning on the side which has the bead slot.
I would say this is a great awning if you need lots more space and maybe need to spread sleeping area out side. Its a 2 man job to put it up though and a step helps to get the pole sleeve over the 2 cross pole at the top. NOTE*** due to me pulling too hard on this I have slightly torn the pole sleeve on one section by about 2 cm. Still works fine and is watertight but wanted to declare that. The rest of it is still in correct working order.
Technical Specifications
> Berth: 2 as standard / 4 with accessories
> Bedrooms: 1 as standard / 2 using the aftermarket inner
> Doors: 2
> Windows: 5 with privacy curtains
> Poles: 19/16mm steel and 12.7/11mm fibreglass
> Pole System: Pole and Sleeve
> Flysheet: 150D RipStop Polyester, Flame Retardant, WeatherWeave Pro with taped seams
> Guy Ropes: High-visibility with double shock corded pegging points
> Colour: Grey with a black trim
> Hydrostatic Head: 5000 mm
> Groundsheets: Loose-lay included
> Figure of 8 Strips: included
> Canopy Poles: Included
> Height: 250cm
> Weight: 24kg
> Pack Size: 77 x 39 x 28 cm
Grab a bargain £250 - Collection Only, Brentwood area Essex
Any questions just ask
