D
dominichayhoe
I think I heard somewhere the LED headlights do not require any of the convertor stickers for driving abroad. Is this correct?
TIA.
TIA.
Just a spare bulb collection I guess for any other lamps that fail.I think I heard somewhere the LED headlights do not require any of the convertor stickers for driving abroad. Is this correct?
TIA.
Apparently it doesn’t need to as it’s a flat beam and not directional according to VWCCI'm sure in vehicle settings the beam can be adjusted for European use
That may well be the case on your T6 ocean but certainly isn't on a T6.1 OceanI'm sure in vehicle settings the beam can be adjusted for European use
The beam is flat enough to not need it for holidaying. But not flat enough if importing to some countries. The dipped beam lamp is a different part no between LHD & RHD vehicles.Other Vag vehicles use the GPS position to adjust the headlight position
(flatten the beam)
in the absence of ant adjustment on T6.1 / Grand I would assume the same applies. (Or the beam is sufficiently flat without any auto adjustment)
Oh, ok then. Silly meThat may well be the case on your T6 ocean but certainly isn't on a T6.1 Ocean
Which is all pretty irrelevant as the Question is about a New Grand California.
