Virg
Hi
I had my water pump replaced recently by VW and the following weekend was away and on hook up. Despite driving about 60 miles and being on hookup all weekend the leisure batteries had fully discharged by the time I got home. The fridge had been on most of the weekend. The hook up was working.
The van went back in to VW they checked it and said it was fine.
Went away again the weekend and had the same problem. Here is a bit more detail and a photo.
The van has driven about 100 miles and on arrival had >60 hrs of charge in the leisure battery
It was on hook up and the hook up was working (ie using kettles etc so not a breaker issue)
The fridge was on at 4 so drawing from the leisure battery after 12 hours on hook up and with the fridge on the leisure battery was showing only >33 hours so is draining (see photo)
By the end of the weekend the battery had drained to only 5 hours despite being on hook up
The solar panels (2x100W) are charging the leisure batteries
Thanks all for any input.
