Leisure battery dimensions for replacement
AmyMac
Grantham
Hi all,
Quick two questions...I am replacing both batteries on a 2019 Ocean.
1. Can I buy exactly the same battery for front and rear leisure batteries? I can't tell if they are the same, as the covers are still in place at the moment.
2. I have measured the length of the rear leisure battery, in situ. The dimensions of the current Varta battery are (approx) L 315mm. Most of the ones I am looking to purchase are around L 353mm. If I look at the spec of my current battery online using the serial number, it shows L 353mm. I'm confused! The cavity under the wardrobe and the seat look very tight, not leaving much wiggle room. Do I need a 315mm or would a 353mm one do, as that is what is says is in there right now?!
Thank you.
Hi all,
Thank you.
Like for like replacement are Varta LA80.
Thanks, just looking at different brands too, and that's where it gets a bit confusing! The Varta LA80's dimensions are stated as bigger than the LA80 that is currently installed. Just wondered if anyone else had come across this, gone with the L353mm, and it was all good.
DIN H7 and DIN H6 (smaller than H7) measures fit, it’s the height that poses issues. It should be no more than 19 cm in height.
L 31,5 fits, but 35,3 is really tricky. You hardly have space to manoeuvre it in the cupboard in the back.
The LA 80s I got from Tanya were exactly the same dimensions as the Varta LA80s they replaced. No problems fitting them.
