Leisure Battery- Fully Charged But Zero Hours of Life
Simbo
Leeds
T6 Ocean 204 4Motion
Hi, hopefully someone has seen this and knows what to do.
On the overhead control panel my leisure battery is showing 10 bars of charge but zero hours of life. The lights, fridge and heater are working so I'm guessing that its a software glitch. Any ideas of why this might be happening and what needs to be done to fix it?
1. The Calculation for the Hours is iffy and not to be relied upon. The Voltage is more important.
2. You could do a Control Panel reset by removing fuses 5,6 7 & 8 as per in this thread and @Loz s post.
3. Failing the above unplug the Battery Module lead attached to the Black -tve pole on each Leisure Battery. Don't remove the module just unplug the 2 wire connector plug. Wait 30 mins and reconnect.
